Old 04-26-2011, 04:21 PM
jeffscub's Avatar
jeffscub jeffscub is offline
Originally Posted by Southtowns27 View Post
Either you have a non-internal resistor coil, the coil is shorted, the condenser is shorted, or the wire from the points to the coil is shorted. It can ONLY be those things to be causing your problem. Should help narrow it down for you. If it were me, I'd go buy a new correct coil and condenser, change the points, and the wire from them to the coil. It could probably use it anyway, and it'll fix your problem
i have a new correct coil, condenser, new points (that are now burnt) and a brand new wire from the coil to the points. fact being, ALL the wiring is new and quadruple times checked for accuracy as per the wiring diagram in the tech section on here. jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
Old 04-26-2011, 04:46 PM
How about some pictures of this setup..???
Old 04-26-2011, 05:48 PM
red211's Avatar
red211 red211 is offline
Sounds like the next step, unless the coil was labeled wrong or bad from the factory.
Old 04-26-2011, 08:32 PM
jeffscub's Avatar
Ok, my Dad and I have figured it out. Everything I was telling ya'll was correct, BUT the coil that was originally on it had a ceramic resistor zip tied on the side, but there were no wires going to or from it. Having a cousin who has a sales and repair shop for mowers (he is WAY high on his parts) looked at the coil and told me that it was a NON-resistor type coil and that it had to have been wired through the external resistor to run and since I didn't wire it through there again, that is why it was burning points and wires. So he gave (yes actually gave) me a coil that had an internal resistor. I installed it, gaped the NEW points, a little gas and guess what????? it FIRED up in about one revolution and purrs like a kitten, absolutely NO SMOKE. Clutch pedal is a little sticky due to crud and what have ya on it. So I thought, while it was running, lets see how well it will pull the turning plow, I hitched her up, went out to the garden, dropped her down and she did extremely well for a neglected, rusty ol' gal!!!! Now, my next little problem is trying to find the next plow day in my area!!!! I want to personally thank each and everyone of you who patiently help me out with what little info I gave!!!!! again, THE greatest bunch of guys a forum could ever have!!! If cubs wasn't a great GT, you guys could make them!!!!!! Below are pictures of the external resistor. thanks again, jeff
Jeff
Old 04-26-2011, 08:44 PM
The above pictures are of NON Cub cadet Parts.
Old 04-26-2011, 09:08 PM
jeffscub's Avatar
oh, yeah, i know. that was a PO add on. he told me they do that due to the price difference. but i would just rather have the one it's suppose to have, like the one he gave me, that way there's no problem. jeff
Jeff
Old 04-26-2011, 10:24 PM
CC1450's Avatar
CC1450 CC1450 is offline
glad you got it figured out Jeff, sounded like you were losing hope there for a bit. Also that is cool it does not smoke, you probably just ironed out the reason someone else had given up on it.
Old 04-26-2011, 11:33 PM
Jeff I'm glad you got it figured out and you might be paying for that coil for years to come!
Old 04-26-2011, 11:37 PM
Southtowns27's Avatar
Southtowns27 Southtowns27 is offline
Good you got it figured out, BUT, the stock coil has an internal resistor. So, the "correct coil" that you got from somewhere was not correct. Maybe take it and get your $$$ back? If you got it from a dealer, they should have known better.
Old 04-27-2011, 11:59 AM
That's awesome, Jeff! Glad you got it going!
