Old 05-05-2011, 09:40 PM
william1041200's Avatar
on my 1200 , I leave the cradle rails in. I drop the front axle (remove the pivot pin) to get to my front engine bolts, then unbolt the 2 rears from the oil pan. disconnect everything else from engine, remove fuel tank and heat shield.
I have done it with front axle in, but there is hardly any room to ratchet a gear wrench , and you would want to punch a baby trying to get those front bolts back in with axle in the way!
Old 05-05-2011, 11:07 PM
ajgross ajgross is offline
Inactive Member
To get to the bolt that are above the axle, what I use is a super cheap socket set that I picked up at family Dollar. It came with a 9/16" socket that is shallow and 1/4" drive. It fits in there great. You just have to jack one side of the tractor up a little to make a little more clearance. As a added bonus, the set came with a thin walled 3/8" socket that works on the valve seat on carbs.
AJ
Old 07-15-2011, 12:37 AM
CC1650Dave's Avatar
After reading this thread and then tackling my 1650, I'm definitely with william1041200 on this. Dropping that axle is easy, and it makes a world of difference in getting to those bolts. Thanks!
Old 07-15-2011, 06:46 PM
The axle does not always come out easy. Jack up the tractor, block up the front axle to one side, and then remove the bolt on the other side with a socket, then switch sides.
