I had the before pictures on my other computer that got lightning ZAPPED.
I'm looking through my picture CD's to see if I stored any there. If I find some I will post them. The 147 didn't look to pretty when I bought her. Rusty and unkept. The previous owner was so cheap, he put a wheel barrow wheel & tire on the right front rather than getting the right replacement tire. I replaced the front tires with tri rib tires. |
![]() Quote:
Hello OLE 147,
I just joined the forum and see that you are from the same neck of the woods here in central PA (I'm in bellefonte PA). Can you tell me where in the this area I can go to get an opinion/possible repair for my 1200? I pulled the creeper drive and found the roll pin pulled from the shifting shaft which connects to the fork. I think all I need to do is to find a slightly oversized pin to replace, but I'm not sure if I need to "rebuild" any other part of the creeper drive. For example, the coupling that connects to the drive shaft is loose. The pin is tight, but I assume that it needs to be a bit flexible to allow the ball/bushing to engage properly. The local Cub cadet dealer just doesn't have the experience with these older tractors. Anyone in our area that you have been using? Thanks, Mike |
