Old 07-21-2011, 09:37 PM
Yep some of the lucky first few 782's that CCC built got the left over CI rear's and front axles. Mine is one of those. It is CCC built with CI IH rear and front axle.
Old 07-22-2011, 12:26 AM
YellowFever YellowFever is offline
Default 782 Gas
I'm pretty sure my 782 gas is a 1980 model so I'm guessing it is IH? It had a Kohler KT17 in it and I replaced it with a M18 Kohler which purrs real nice.
Old 07-22-2011, 01:24 AM
ajgross ajgross is offline
Inactive Member
If you want to go deeper, there are two styles of cast rearends. There is the red cast and there is the black cast. The Red cast had course splined axles while the black cast has fine splined axles. Even though it has fine splined axles, the carrier isn't as strong as the one found in the aluminum rears.
AJ
Old 07-22-2011, 12:12 PM
TheSaturnV's Avatar
Yep some of the lucky first few 782's that CCC built got the left over CI rear's and front axles. Mine is one of those. It is CCC built with CI IH rear and front axle. [/IMG]
Didn't all CCC Cubs retain the same CI front axles through the 82 series. Both my 882 and 1211 have CI front axles.
Old 07-22-2011, 04:00 PM
Yes, they did, but if you're really anal about correctness, the IH ones are red, CCC ones are black, and there's probably a few really early CCC ones that are IH-made axles painted black. The IH-made axle would have IH numbers cast into it, and the CCC ones would have a CCC casting number. Some things like the gas tank made it really far with an IH number...my 1987 1872 has an IH gas tank...
Old 07-22-2011, 06:06 PM
JALLEN JALLEN is offline
Default 982 rear end
just to throw you a loop in this rear end discussion i have a yellow and white ih 982 with a cast iron rear end made in 83 how rare is that?
Old 07-22-2011, 06:36 PM
Any yellow 982 before serial #720,000 has an iron rear as has been already mentioned. If it's yellow, it's not IH, it's CCC-built. It's possible there was a factory oops and IH decals were put on it. I have seen yellow tractor decals on a red one, and vice versa. That seems to have happened more often than you'd think.
Old 07-23-2011, 10:08 AM
i can show you pics if you need them Ray Weaver said in over 3000 cubs he has never seen one but i do have it. ih on the rear fender on the hood and was on the headlight grill
Old 07-23-2011, 02:27 PM
aagitch's Avatar
aagitch aagitch is offline
I think what Matt is saying is that it can be yellow/white yet still have the ih decals on it that would normally go on the red ones. I've seen a few pics. They look pretty cool. With that said, if an 82 series is yellow/white from the factory no matter what decals are on it, I'm pretty sure it was built when CCC took over.
Adrian
2072 (789513)
Old 07-23-2011, 03:21 PM
That's exactly what I meant. I suspect they'd run out of decals once in awhile, and use some from the other line to keep things moving until they were replenished.
Ray must have forgotten about the yellow 782D he posted pics of on another forum. It's was the same as you are talking about....yellow and white tractor with the red tractor's decals.
