Old 08-09-2011, 12:08 AM
Just so everyone knows I don't blame David. I blame the PO!
Old 08-09-2011, 12:25 AM
Hey Duke, that ball will go into the rear coupler then the drive shaft should slide in next. Think it might keep the shaft from flexing too far in or something. My 1250 had the same ball with the hydro. Make sure the front drive shaft bushing is in good shape. This is a good time to replace it too.
Attachment 14040
I forgot to add that I've checked them and greased them already. They were in great shape. Looks like half of the works was done right and the other half was welded.
Old 08-09-2011, 09:39 AM
Ever get that feeling that your forgeting something? Well about 2am I went into the garage digging thru my piles of parts and I found another 3 pin driver! Whee! I got two spare motors last fall and forgot that one had a 3 pin driver on it. I moved the motors to a friends house so I wouldn't have to trip over them but I took the 3 pin driver off the motor and put it on the shelf next to the other spare parts! I've only seen a handful of 3 pin drivers and this one is the best shape. I'll get some pics and post them later. Right now I'm feeling pretty happy that I saved some $$ and can get this clutch rebuilt and reinstalled today.
Old 08-09-2011, 09:41 AM
william1041200's Avatar
Duke - it looks as if everyone has you going in the right direction! That ball does go in the flex joint at rear of drive shaft.
Looks like P O got his balls in a bunch or lost his marbles or .....
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 08-09-2011, 09:44 AM
Thanks William! How ya been? Been meaning to but when I think about it's to late.
The PO had somethng else on his mind when he was working on the clutch!
Old 08-09-2011, 11:02 AM
Looking forward to your pics!
Old 08-09-2011, 09:54 PM
I'm gonna have to do my 1200 clutch soon, appreciate the pics.... I have a spring that is broken and the throwout bearing is noisy or squeals....If it was a MTD it would a been dead years ago..
Are you getting the plates resurfaced or new ones??
Old 08-10-2011, 07:03 AM
Duke- I do hope you put that ball in the rag joint coupling! It transfers the clutch spring load to the transmission input shaft when you push the clutch pedal. Without that ball, the rag joint carries the load, but will let the shaft push back before your clutch disengages. I bet that rag joint is trashed, and could even have helped the 3 pin plate failure.
snow/dirt plow
QA-36 snow thrower
Old 08-10-2011, 08:33 AM
Sounds like you need a teaser spring and throw out bearing. Unless the large spring broken. I'm going to have the plates refaced.
I'll be putting the ball back in there! Rag joint is in good shape.
Old 08-10-2011, 11:02 AM
MrGitrdone41's Avatar
That clutch is gone! It will have alot more power with a new clutch.
1988 1812,dual ports
1973 108
1968 125
