Old 09-21-2011, 08:23 PM
Guitar Guy Guitar Guy is offline
Default Update
I got the carb. kit from the local supplier who had it in stock for $13.50. My mechanic friend helped me install the kit, adjusted the carb. and got it running great.
However, the next day, I ran the tractor a little and the float must have stuck again because it pours gas out the air cleaner cover as soon as I turn the valve on.
We cleaned it very good, and my tank, filter, lines, bowl etc, are all clean. I'm wondering if the black flexible "baffle" could be hanging the float up some how. Does anyone know if it's advisable to do away with the baffle? We're going to try to adjust the float in a day or two, but other than that or the baffle, I dont know what it could be. Any ideas appreciated.
Josh P
Old 09-21-2011, 08:44 PM
LarryW's Avatar
LarryW LarryW is offline
Maybe you could take the float bowl off and leave the rest of the carb on. Hold the float up and turn the gas on. See if the needle is leaking or not. Let it down and up a few times. If that works then you know the float must be out of adjustment or catching on something. I assume the float comes new with the kit? If not, maybe there is a pin hole in it and is full of gas.
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 09-21-2011, 09:08 PM
The float doesnt come with the kit, but mine was in good shape and didn't have any gas in it.
JP
Old 09-21-2011, 10:36 PM
I'm betting you have some junk between the valve and inlet not letting the valve seat completely when the bowl is full allowing the fuel to continue to flow. Some compressed air thru all the ports would help. Did your buddy soak the carb in carb cleaner for a few hours or just throw the kit on and go?
Old 09-21-2011, 10:48 PM
WV boy WV boy is offline
Man, all i can say is that i love this site. im having the same problem with my 100. i just rebuilt the carb last winter, (sub 32 degree when it started leaking) and now it is leaking again sporadically. when i tap on the bowel it seems to fix it. i was thinking it was some dirt at the float pin. ill definately be keeping up on this thread.
Old 09-22-2011, 02:36 AM
We didn't soak it, but we used a good spray cleaner and compressed air. And the carb was not visibly gummed up or dirty,, had not been sitting with gummed up gas, etc. He is a good mechanic, has owned his own auto shop, and has maintained a fleet of golf course equip for many years, as well as built and tuned Harley engines.
We're going to try adjusting the float while the carb is still attached. Does anyone know anything about that baffle? That thing just looks like it could interfere.
JP
Old 09-22-2011, 08:08 AM
I have rebuild 20+ carbs and I have never had a problem with the baffle gasket interfering. If it is, you may have it installed incorrectly.
Old 09-22-2011, 08:52 AM
cub1450's Avatar
cub1450 cub1450 is offline
When I got my 129 my float was stuck and all I had to do was take the bowl off and move the float up and down to work it loose and it worked for me.
Jed
1975 1650SGT Work In Progress
1974 108 (Mint) #510358
Old 09-22-2011, 10:22 AM
jeff967 jeff967 is offline
Josh P
make sure that the bowel vent is not plugged with a bug. yes I said a bug, mine was a yellow jacket!!! if the bowel vent is plugged the fuel WILL start a siphon at the main jet and never fill the bowel to lift the float. I was convinced that granddaddy was haunting me by holding the float down!!!!!
Old 09-22-2011, 05:54 PM
If the vent is completely plugged, the tractor will only run at idle, if that, so assuming his tractor runs, this probably isn't it.
