I guess I like the factory look when the option is available. IMHO
Dale 147-Restored___________________882 Diesel Hydro lift (not installed)___________44" Deck 48" Deck_______________________QA-42a/b Snowthrower Rear lift ________________________XMW cat-0 rear lift Model 2 tiller____________________12" cat-0 Brinly plow |
![]() Quote:
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
Here is a poor picture of a 3 point that my friend made for me. I gave him the dimensions and he made it. I think 1 3/4 square tubing with sguare plugs welded on the ends with the 1/2 or 5/8 rod drilled then he made the lift arm. Works great as the orignal one. I just don't use it because of the weight box on the back.
This is what I done.2 in. square tubing notched and welded together and pressed pipe in the tubing
with my press(a 12 pound slegde).
Jed Proud to be a FFA member Westmoreland,TN Chapter 1978 Cub cadet 1450 IH Hubcaps 1975 1650SGT Work In Progress 1974 cub cadet 129 with sleeve hitch/spring assist 1974 108 (Mint) #510358 brinly 12 in plow,disc,8 in plow ,2 42, 2 44A ,50A DECKS #40 boxblade,can`t keep up with the rest lol ![]() ![]() ![]() ![]() |
![]() Quote:
1967 IH Cub Cadet 123 1978 IH Cub Cadet 1650 19?? IH Cub Cadet 682 |
Seems like you have this well thought out...self locking nuts, good solid steel, bearings for pivots, etc. What are your thoughts on the bottom plate? Do you think you will go with a double plate? You obviously can fabricate and weld...will you put ears back to the axle? I've been contemplating doing my own as well...your work has encouraged me to move forward.
Thanks ![]() Hope to see photos as you progress, Jim |
Great job!
![]() Quote:
Dan, It fits perfectly between the frame rails and yes i`ll bee adding an arm to it. It looks a whole lot better in person because it has silver spray paint,slag,grease,and a few welds that have to be ground down on it.After I get done with it i`m going to sandblast it and paint it yellow.
Here are some pics of it almost done all I got to do is paint it cub yellow tomorrow
