Old 09-08-2011, 09:19 PM
Hornets,
The deck will fit if you use the correct undercarriage.
The rototiller will fit.
Old 09-08-2011, 09:24 PM
Great find Larry, you'll like it, alot!
Old 09-08-2011, 09:42 PM
LarryW's Avatar
LarryW LarryW is offline
Thanks Zippy!
Hornet, This operators manual may help you. Tells a lot including what you need and setup and operation. 1A tiller operators manual
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 09-09-2011, 12:08 AM
Originally Posted by LarryW View Post
Thanks Zippy!
Don't forget Bill's awesome guide!
http://www.onlycubcadets.net/forum/s...ad.php?t=12320
Old 09-09-2011, 12:10 AM
Originally Posted by Hornets View Post
I was given recently a 129 cub cadet It needs complete restore. It come with a 1A U1111 6 tine roto tiller. I found a 3 gblade 42 " mower deck good shape off of a 105 cub cadet. my mule drive has some of the arms cut off. will the mower deck and roto yiller fit this machine. Hornets
Hornets,
Don't forget to use the steel pulleys! The stamped steel ones on the mower mule drives are not meant to be used for tillers.
Old 09-12-2011, 07:36 PM
Hornets Hornets is offline
Default 129 cub cadet
I was given a 129 a while back but needs the following parts. Hood and I guess3 point arms but the tiller has arms on it and a T, handle for adjustment of the tiller.I have the mule drive that came with the tractor.Would that work with the mower deck that I got from a 105 hydro. I also need the tiller mount and gear box. and a shroud that covers drive shaft between gas tank and engine. And grill with headlites. Thanks for your help. Hornets
Old 09-12-2011, 08:40 PM
LarryW's Avatar
Methos, I saw that but I dont understand why? Is it just a strength issue?
Hornet,
The narrow frame 105 mule drive is different then the wide 129 but the deck will work with both. The tiller mounts to the rear pto gearbox mount with those arm. The single sleeve hitch pin is what lifts it with a chain and a T handle bolt. There are 2 T bolts. One on the chain and other is to tighten the smaller tiller belt. I would post your wants in the wanted section of the site. You will get better results.
Larry
Cub Cadet 1811
Old 09-13-2011, 11:14 AM
Larry
Larry the stamped steel pulleys will come apart under load. Tillers and thower/blowers both need to use the steel pulleys.
Old 09-13-2011, 04:44 PM
LarryW's Avatar
Snowthrower too? crap. I have used that for the past 3 winters with the stamped pulleys with no problems. Guess Im pushing my luck.
Actually I received the snowthrower with the tractor so I'm not sure how many other years it has ran it?
Cub Cadet 1811
Old 09-13-2011, 04:56 PM
I've heard that you can get away with using one steel pulley on the left side of the mule drive. I've seen the steel pulleys listed for $85 each and the replacement bearings are $35 thru my local bearing supply house.
