I've used a 2x10 piece of lumber as a ramp to break the bead. Just remove the wheel from The tractor and remove the valve then lay the wheel on its side and place the 2x10 up on the tire only not the rim but close to it then drive your truck slowly up until the bead let's go. Then fill the tire with fluid for weight. THIS IS CRUDE BUT IT WORKS IT CAN BE HARMFUL IF THE RIM FLIPS OUT SO USE CAUTION.
