Old 09-23-2011, 11:08 PM
LarryW's Avatar
LarryW LarryW is offline
If I could get to that pulley or come up with an idea to mount one there I could have the cylinder mounted where the e lift was and the pump working off that little pulley and mount the valve there. I think I have a power steering pump off an old gm something and I already have a small valve and cylinder off an old montgomery wards gilson made garden tractor. So basically it would just cost me hydraulic oil and hoses to do this if it would work.
The power steering pump seems to work with for this guy.
http://www.youtube.com/watch?v=PSAtLNn8NwE
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 09-23-2011, 11:45 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
Well I hope the NF hydro will fit on a 147!! I have one layin around, and will check tomorrow.
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 09-24-2011, 01:24 AM
scleve scleve is offline
It will fit. I have one already mounted. It is the same as the one on my 107, 106, 127, and 124.
Old 09-24-2011, 07:50 AM
mmzullo mmzullo is offline
I have seen an aux hydro lift on a 147. I think he changed the drive pulley to a double pulley. I dont think the belt will fit that pulley on the engine you have now. I do have a picture of the tractor but not on this cp.
Old 09-24-2011, 09:56 AM
Scott,
Did your 147 have holes for the pump mount,or did you have to drill them?
Old 09-24-2011, 10:20 AM
I found the picture of the 147 but it was an ad on ported hydro pump with piston.
Old 09-24-2011, 03:56 PM
LarryW's Avatar
Thats cool. It also has a non oem motor like I think the quitlines used and john deere.
Yamaguys 147 had 2 pulleys on the drive shaft. I found his thread. He has pictures too. Maybe I will do that.
http://onlycubcadets.net/forum/showt...ght=147+pulley
Cub Cadet 1811
Old 09-25-2011, 02:48 AM
To get the belt on you'll have to slide your motor forward and tilt it forward to have enought room. That's how I install my NF hydro pumps and how the manual shows it.
