Old 09-24-2011, 04:01 PM
only1stegall's Avatar
only1stegall only1stegall is offline
if i am understanding this link correctly the little bracket labeled " high speed stop " should not matter, right? because the governor should slow the engine down as it reaches the maximum speed.
mowing LT1045, plowing 149, tilling 149, parts 149...
plows, harrows, cultivators, box blade, tillers...
I like fast cars, big trucks, and yellow tractors!
My photo album
Old 09-24-2011, 05:00 PM
As seen in the RED box, my linkage and spring looks exactly like this when together. I set it like this per the FSM description
Good!
As seen in the BLUE box, this " high speed stop" bracket is gone form my tractor. Is THIS the limiting factor?
You need the L bracket. This is what sets your high speed RPM. More than likely your problem. With the bracket you can adjust your RPM's to 3600.
As seen in the GREEN box, this is no present, as I have a throttle control cable coming from the dash board instead.
That picture is just representative of the throttle cable, does not make a difference in your case.
Old 09-24-2011, 05:16 PM
Check your PM's.
