Old 08-18-2009, 05:57 PM
MBounds's Avatar
MBounds MBounds is offline
AJ: The term might be better understood if the whole term found in the Hillman catalog is used: "thrust bushing" . The pressure is supposed to be on the flat sides. That is why it kinda looks like a washer. For the Kohler carb fix, we don't use it as a "thrust bushing", but work it does.
Myron B
CCSupplyRoom
Old 08-19-2009, 09:09 AM
For all this talk about the Hillman Bushing, washer or whatever you want to call it, I have yet to see a picture of it.
Myron, how about posting a picture of it....????
Old 08-19-2009, 09:15 AM
dkish dkish is offline
do a search on this site under throttle shaft. its shown there. this fix is the bees knees!! it works great!
Old 08-19-2009, 09:26 AM
RPalmer's Avatar
RPalmer RPalmer is offline
That along with a choke shaft repair are in the Kohler service manual.
I saw a washer repair @ cubfaq. I thought that was the washer in question.
Old 08-19-2009, 09:29 AM
MBounds's Avatar
How's this?? You'll notice that they are just about the same...The Hillman thrust bushings are just a bit thinner than their Kohler cousins....
Myron B
File Type: jpg Hillman 58087A vs Kohler bushing 001 [1600x1200].jpg (19.8 KB, 41 views)
Old 08-19-2009, 09:47 AM
clint clint is offline
The throttle shaft bushing is one fix that is super easy, and a big bang for the buck. I'm not sure what it cost to purchase the bushing as I made my own, but it's so simple top tap the bushing in, and it really smooths up the throttle shaft while taking out any play, and will also prevent (or help) wearing out the aluminum carb body. One thing I didn't have a clue when doing my first one.. I thought the ones I done just fell out, however they did not come in the carb originally.
If I had enough stock to make several i would have turned out 15 or 20 while set up to send out to those who can't find them local like I me... I checked everywhere local to me with no luck.... I think I read somewhere that someone also used a plastic, or graphite washer/bushing that also works great. I have worked with small press in graphite bushings, I would probably prefer bronze in the case, but the graphite would have some outstanding properties for this application.
Old 08-20-2009, 05:04 PM
klejeune's Avatar
klejeune klejeune is offline
I used some aluminum and made a bushing for mine. That way when it wears away I can replace it and still won't have any chance for the throttle shaft to wear.
I like pie
