I have pulled both (10" and 12") with my 1811..... and I think the 12" pulls close to equal to the 10".
-105___ Tiller |
Nice find on the plow. Your 149 will have no problem pulling it.
Something does not look quite right with the 'point' on that plow...it's either broken off or really worn.
10 3/4" wide is probably a 10" plow. A 12" plow would be closer to 12" than 10". |
looks like the point is broken off. You'll want to replace that you'll have a hard time getting it in the ground and maintaining a consistent depth. They're still available from brinly.
Adrian 2072 (789513) |
Your 149 will have no issue in the area of power, all you got to do is put some weights on it and it will pull it just fine. You might be able to get your point fixed by building it up with some weld and grinding it, but I'm sure it would be much easier to just get a new one.
I just bought a 10" plow share from Brinly a couple weeks ago and it is about $43 shipped to your door.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
i looked at it real close, and I believe rather then being broken it is only worn down. don't let the fresh paint fool you... the fella obviously painted it up for the swap meet.
Ill see how it does, if it fights me ill order a new one.
Allen mowing LT1045, plowing 149, tilling 149, parts 149... plows, harrows, cultivators, box blade, tillers... I like fast cars, big trucks, and yellow tractors! My photo album
That looks like a 10 to me. We have several 10 inch plows and two twelves and all are 10 inch have that square on the top/back of the plow. Ether way your 149 will pull the plow fine. I personally use a 14 horse with my 12inch
Will proud owner of cub 122,128,70,100,and 682 |
One of my plows are worn down pretty close to that, and it still plows fine.
-105___ Tiller |
