Old 11-18-2011, 11:04 PM
cub1450's Avatar
cub1450 cub1450 is offline
Whats the difference between putting 26x12x12s on a gt with a standard pump and a super with a standard pump instead of a super pump .
Jed
1975 1650SGT Work In Progress
1974 108 (Mint) #510358
Old 11-19-2011, 12:32 PM
ajgross ajgross is offline
Inactive Member
Cub never used a 10" rim. The supers use the same size rim as a standard GT only with a different offset. The rim size should be 8.5"x12".
AJ
Old 11-19-2011, 01:05 PM
Nothing, assuming the super with the standard pump also has the GT rear instead of the SGT rear.
If you mix and match a super pump and GT transaxle or vice versa, you'll wind up with a broken rearend and/or pump. They are two different gear ratios.
Old 11-19-2011, 07:17 PM
JayBrd's Avatar
JayBrd JayBrd is offline
Or if you are asking if there is a change with running a 26" tire instead of the "standard" 23" with a GT tranny as apposed to a SGT. It seems a bit faster, but I cannot tell if it effects the pulling power ect.. So if that is what you mean, it's too close to tell to be honest..
Jay N.
Eau Claire, WI
RED 82 Series...
Old 11-19-2011, 07:37 PM
CHWNY's Avatar
CHWNY CHWNY is offline
Matt, I thought the rear pto shaft was the difference. Is the pump larger? Are the supers higher or lower geared? Are the rears the same other than the input/drive gears? Thanks
Clay
Old 11-19-2011, 08:23 PM
72-149's Avatar
72-149 72-149 is offline
Originally Posted by JayBrd View Post
Yep!
All I had to do with the fenders was place 3-4 washers at each pan bolt....
i didnt know this site had porn on it !!!!! i could look at this all day everyone likes a red one, shes got a nice rear .... lmao
Old 11-19-2011, 08:48 PM
jbollis's Avatar
jbollis jbollis is offline
The pumps them selves are the same but the output "drive" shaft that goes into the reduction housing is different. There are 2 different gear ratio's . One for the super's and one for the GT's. So there are 2 different tooth counts on the output "drive" shafts. If I remember correctly, it is a 2 tooth difference (66 for the gt's and 68 for the super's) .
The supers are lower geared to make up for the increased tire diameter.
The rears are the same, just the reduction gears "ratio's" are different.
Sold everything but one.
