Old 11-20-2011, 10:23 AM
Yes exact duplicate, same series of tractors.
Old 11-20-2011, 06:27 PM
cub cadet people II's Avatar
cub cadet people II cub cadet people II is offline
Angry
when I put my 102 ones on they were super sticky and very hard to get off the paper!
Mike
Way too many!: 4 digit Original’s #1218 and #8820, 70, 71, 72 x2, 73, 86, 100, RESTORED 102,105,122,123,124,125,147 with Danco Loader, 149, 1000, 1572 Diesel with 3 pt, (2) 42” snowplows, 54” Haban Power Angle Blade, (2) 38” decks, (2) 44” decks, (2) 48”decks, #1 cart, #2 cart, #3 cart, #4 cart, Brinly Moldboard plow, Brinly Cultivator, Brinly Disc Harrow,3 sets of IH wheel weights, IH Windbreaker Cab, QA36A blower, QA36 Blower,Boxblade, Giant Vac System off a 73!
Old 11-20-2011, 08:16 PM
MrGitrdone41's Avatar
I put mine on dry on my 128 and 73. You want to leave the backing tape on and tape the decal on were you want you want it and get it stright. Than peal a little on the backing tape back to get to stick at one end than peal the tape back as you go. If it is not right peal the decal off and do it again it will come off if the paper is on the back alittle it will not hurt the decal. It toke me 2 hours to put deals on my 128 and around a hour to do the 73.
1988 1812,dual ports
1973 108
1968 125
Old 11-21-2011, 09:49 AM
cub123's Avatar
cub123 cub123 is offline
I have had good results with windex on my motorcycle decals,they are 3M, but it might work just as well with the cub ones.
Old 11-22-2011, 10:16 AM
Lonestarcub Lonestarcub is offline
Default Decals
Iv'e worked alot with vinyl decals and I like to use the spray bottle with dish soap to apply.Make sure you let them cure real well in direct sunlight after your finished,it will smoth the decal out and it will truly bond the decal to the surface and makes the bubbles that you pricked with a pin disappear.
Good luck,Bruce
Old 11-22-2011, 05:51 PM
Sugarmaker's Avatar
We need decal pictures!
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 11-22-2011, 06:16 PM
Regards,
Chris
I got a decal picture!!
Sugarmaker, Is this what you had in mind??
Old 11-23-2011, 05:51 AM
nikster's Avatar
nikster nikster is offline
When all fails, read instructions. DUH!
Thats what I should have done from the very start. 'READ THE INSTRUCTION's.'
Clear & simple; Add 3/4 drops of liquid soap to 12oz. of H2o.
Nik,
Old 11-23-2011, 08:49 AM
jlampe94's Avatar
jlampe94 jlampe94 is offline
I put all my decals on dry. Ive done the water thing once and didnt like it. I just get them lined up on there and use a peice of painters tape to tape the one end then to hold it straight then go from that corner peeling the backer tape off and working the decal on using a clean tshirt in small up and down motions, doing it that way leaves you with no bubbles.
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4.
Old 11-23-2011, 08:54 AM
Sugarmaker's Avatar
That is a decal of some type of animal looks like it might be a deer I actualy have a Deere hat. I feel funny wearing it! I and not a Deere type of person
Nik Are you OK???
Regards,
Chris
