Old 11-22-2011, 10:23 PM
Originally Posted by MrGitrdone41 View Post
That's what i did and it did not mess up the rims.I know what Matt is saying they can bend i'm doing to a spacer in the next time i put them on because they weren't inline with the inner rim. If you have 23x10.50/12 the wheel base is 56 inchs!
MrGitrdone41, wheelbase is center of front axle to center of rear axle. The 56" is just width.
I have dual 6-12's on my 122 with the spacer method and have not had any problems.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Donny Curtis's Avatar
Donny Curtis Donny Curtis is offline
Thanks Guys for all the feed back, I did order the ring type from Miller Tire, the reason that I have the 23-10.50-12 wheels is because that is what I Had on the Cub and what I could get in my area I live in, I will have them on a 582 real soon, until I get a hydro to put them. Hope I have a 1250 that I will fix up with the help of a 1650 frame, to put my front blade to use around the house and a few projects around my Mother's house, never know what is going to come up for a Cub to do. I will just try to be ready for what ever does. I will let everyone know how it all works out. Thanks
Donny
Old 11-22-2011, 11:13 PM
MrGitrdone41's Avatar
Randy
Sorry wrong wording!
1988 1812,dual ports
1973 108
1968 125
Old 11-22-2011, 11:18 PM
Did you order the bolts and everything?you have to get the 10in bolts. idk if there the right lenth tho. When i made mine 10in bolt were to short so that is y i used the all thread i caould not find 12in carrage bolts. The spacers will help. went u get them put up pics
1973 108
1968 125
Old 11-22-2011, 11:26 PM
I order the 10 inch bolts, when I get them on I will put on pictures , thanks
Donny
Old 11-23-2011, 11:23 AM
Donny, here's a pic of my adapter. The wheel weight is hiding some of it. You'll see how it works.
Old 12-02-2011, 09:06 PM
Default Duals
Well I got my dual adapters in from Miller tire, went on great, the 10 inch bolts worked great, with the inside rims have a different off set, also have the valve stems on the inside of the rim. so it great for keeping check on air pressure, with the other rims having valve stems on the out side, just worked out that why so I did not have to break down to turn tires, talking about a time saver. Can wait to put it to work, Now working on a deal to get a 1250 with a blown motor, I have a 1650 frame, going to rework the to into a work tractor with a hydro lift, have to wait to see how bad the motor is to see which way I need to go on the rebuild. Here is some pictures of my once puller, now a pusher a 582 with a 25 hp Kohler Command with the duals and front blade.
Donny
Old 12-02-2011, 09:15 PM
cub123's Avatar
cub123 cub123 is offline
Looks awesome! But I'm not sure it will Push snow to well with the duels sticking past the blade, but hey, it looks cool!
Old 12-02-2011, 10:11 PM
Default Duals
Hope I don't have to push snow, Hope I 'm only pushing dirt, sand and gravel But who knows, will see what comes up.
Donny
Old 12-02-2011, 10:49 PM
Sweet setup Donny!
