i was also thinking about drilling and tapping the small pad that sticks up off the rear and putting a bracket in there too, what do you guys think? is there anything in there to worry about?
![]() Quote:
![]() Looking forward to your pics! |
![]() Quote:
![]() ![]() Yes I would love to have one too for the BRS.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
You have a BRS you don't need a FEL!
![]() Yes I am a show off! ![]() |
![]() Quote:
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4. |
thats a good idea, i never thought about using a shaft collar, that would work good, i had some 5/8x7/8x1 bushings laying around i was gonna use them.
ok didnt get alot accomplished today cause my wifes grandmother went to the hospital, so i spent my morning there.
but i got the brackets made up and boy is it strong! i cant believe just how strong it is, im very happy with the way it turned out. ![]() ![]() it is very sturdy, but there is a problem. once i weld on the upper lift arms, thats it, it can never come out again unless i do something different..... i dont realy want to bolt the lift arms on cause they will just work loose, but what i am thinking is the original holes for the lift arm.... if i notch them, atleast i can remove the rockshaft as a assembly, and do repairs outside of the tractor. gotta run and get some more bolts and another 5/8" drill bit, and do some errands and get some dinner then ill be back out and maybe make the lift arms, then the rockshaft will pretty much be finished. |
You could put them on with roll pins like IH put the lift handle assebly together on the x9 series. Or use grade 8 bolts. I like what CADplans idea is tho.
or just put a bolt throught it...... i guess ill have to get some more sleeves or make some......
no comes the tricky part, ill have to either order some weld on lift arm balls.... im debating using cat 1 balls and putting the cat 1 to cat 0 bushings in them that would work..... then i could use cat 1 drawbar that tsc sells....... i guess ill be making another trip to tsc in the morning..... |
