Old 12-23-2011, 06:29 PM
cubs-n-bxrs's Avatar
Originally Posted by Flatbedford View Post
I had the engine out of my 125 last summer. Too bad I didn't know about this then.
Flatbedford if that is the original engine there shouldn't be balance gears in it.
Old 12-23-2011, 06:39 PM
Flatbedford's Avatar
Please explain this to the new guy. Are they only in later engines?
Steve,
Former multiple 149 owner.
Old 12-23-2011, 10:44 PM
ljones's Avatar
ljones ljones is offline
Only the later engines had ballence gears. Dave Kirk knows more about kohler k-series engines than kohler and he created the original crank ballence kit http://www.kirkengines.com/
Old 12-24-2011, 12:43 AM
red56turbo's Avatar
Where is the dipstick for your engine? If it's at the top under the hood, it won't have balance gears. If it's on the side by the carb (cam gear cover), then it originally had balance gears. They moved the dipstick to the cam cover because it would interfer with the gears otherwise.
Josh
Diesel Cub Cadets...........
Old 12-24-2011, 09:52 AM
CHWNY's Avatar
CHWNY CHWNY is offline
red56turbo, Do you know if Kohler used a plug in place of the old dipstick or was the casting changed?
Clay
Old 12-24-2011, 10:44 AM
Thanks. I am good. That must be why the dang things shakes so much at idle!
Steve,
Old 12-24-2011, 08:48 PM
MOturkE's Avatar
MOturkE MOturkE is offline
I wondered how one could tell if they were cursed with balance gears besides opening the engine. So, since my 12 HP Kohler has a dipstick on the front, right-hand side, it doesn't have them? Cool!
Proud to own a 1965 Cub Cadet 122.
Old 12-25-2011, 01:58 AM
red56turbo's Avatar
Clay,
I'm assuming the casting was changed. Just looked at the 169 and there was no provision for an upper dipstick. The 124 and 109 both have the upper dipsticks and it was too late to check the others in the shed. If time allows tomorrow, I'll check the 129 and 149 tomorrow.
On a side note, correct me if I'm wrong, but I believe that none of the 7 or 8 horse motors ever had balance gears, only the 10+ horse motors. IIRC, when the 147 came out, they had the top dipstick with a stub dipstick to allow the owner to fill the oil from there and the bottom camcover dipstick to actually check the oil. The stub dipstick on the top allowed room for the balance gears. I may be off on these two details so someone please correct if I'm wrong.
Merry Christmas everyone!
Josh
Old 12-27-2011, 10:23 AM
I just picked up a 149 yesterday. It has the dipstick on the carb side. I guess I'll be going in for the balance gears. I think the engine will coming out to do some other stuff anyway.
Steve,
Old 12-27-2011, 11:35 AM
I doubt they would have changed the casting. It's the same casting, but machined differently.
