Old 01-01-2012, 11:08 AM
MrGitrdone41's Avatar
I have a factory manual using the mower frame as a bracket and used wheel weights as the weight. www.ccmanuals.info/pdf/ that is the website site i got it from. I know that you don't have a welder but if you have a sawall and a drill you can made the braces for it.
1988 1812,dual ports
1973 108
1968 125
Old 01-01-2012, 05:21 PM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
Thanks gitrdone Im looking at your link.
Here was what I was thinking. If I bend the mule drive where the red lines are and then weld it and brace with a piece of metal I can then mount it upside on the front of the tractor. I was thinking about drilling holes and bolting it on to the front of the frame. Of course there is some tweaking that would have to be done and I would be limited to only a couple of weights due to the size of the drive. See picture below
Don Smith
Old 01-01-2012, 11:03 PM
dieseldan123's Avatar
Two or three 42lbs suitcase weights would do you good for this project!
If you can i would cut and add steel to the arms on the bracket to move it forward enough to clear the frame. That way you wont have to bend it and it will still use the QA on the frame. The studs that lock into the QA will need to be cut and moved back to lock in position. All in all you can have this modified in no time and still have the full function you wanted too! At the same time you could also decide to make it a dual purpose project and make the bracket a bumper too but this is just a thought only. Looks like your off to a good start and looking forward to progress updates!
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 01-10-2012, 08:15 PM
Sam S.'s Avatar
Sam S. Sam S. is offline
Not that these are really suitcase weights, but I didn't feel like starting a new thread when this one covers the same points basically. I made this bracket to fit on the back of my 102 to add weight for plowing snow. The weights are 28 lbs. each and came from an old silo unloader that we were scrapping. I then made the bracket out of scrap steel laying around the farm to attach them to the rear of the tractor by utilizing 6 of the 7 holes that hold the rear cover on. There is also a hole cut out for the oil check/fill plug. with all three weights and the bracket I was able to add about 100 lbs. A piece of wood can be put in as a spacer against the two bolts that hold the weights in to use only two or one of the weights. If a need arrives (as in I acquire a plow) I might make a bracket to put these weights on the front of one of my cubs. Also the cub shown in the pics is just another 102 (not running at the moment) that I used to take measurements for the bracket. It will be put on my 102 up at school for plowing snow if we ever get any.
-Sam
Old 01-10-2012, 09:35 PM
jlampe94's Avatar
jlampe94 jlampe94 is offline
Looks good Sam!
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4.
Old 01-10-2012, 09:49 PM
EricR's Avatar
EricR EricR is offline
That looks great!
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 01-10-2012, 10:28 PM
dsmithjr's Avatar
Default Suitcase weight bracket ideas
Thanks for the reply's guys those are some great ideas. I finally got a chance to brainstorm on my idea and I've posted a pic of the mule drive stuck on the 108. I think its gonna be to high the way its is so I'm going to rethink the positioning and consider cutting the mule drive down.
Don Smith
Old 01-10-2012, 10:39 PM
Very nice, Sam!
Old 02-08-2012, 10:07 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
you guys have some good ideas posted here. Im going to try to fab a bracket for mine.
do you have any new pics to post ?
Doug
Original , 100 , 125 , 582
Old 03-09-2012, 05:41 AM
yesmar74's Avatar
yesmar74 yesmar74 is offline
Default bracket
Doug here's what I came up with. I made it modular so I could possibly add a grille guard-bumper-suitcase bracket or what ever. If you don't want to use slab weights like I did, you could just use suitcase weights or hang anything on it. Good Luck
DSCF1105.jpg Just slides onto the mule bolts and slide in 5/8" rod
DSCF1106.jpg Bolts can be as long as needed or no bolts at all
DSCF1107.jpg These slab weights are old 75 pound IH frame weights
DSCF1102.jpg I've got the rear taken care of with 9 gallons of fluid in each plus the wheel weights
The wheels,tires and fluid weigh just over 90 pounds
By the way the Briggs repower came out great. SMOOOOOTH
I've been working on the 149 now, getting it ready to sell or trade.
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
