Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Onan Engines
Old 01-01-2012, 05:48 PM
BThein's Avatar
BThein BThein is offline
It could be so many things ,but just yesterday the Onan in my 982 started to skip and pop up though the carb.I thought I had it running pretty well and gotten rid of the engine surge after a carb cleaning and adjustment.I was a little ticked because I wanted to move on to other work on it I had replaced the plugs and wires and I thought more carb problems or bad gas till I caught out of the corner of my eye spark was jumping from the spark plug boot on the left cylinder to ground .I twisted the boot away from the head and it ran fine.I'm going to upgrade the wires and see how it goes.
Bob
Old 01-01-2012, 08:57 PM
72-149's Avatar
72-149 72-149 is offline
how do you get to see price's on the site kirk engines
Old 01-01-2012, 09:13 PM
If you are trying to use Firefox to see his website it won't work. You have to use Internet Explorer. The prices are in the descriptions.
From Kirks main page:
This website is designed to be viewed using Microsoft Internet Explorer. Using other browser software (such as FireFox) will cause deletion of some information.
Old 01-02-2012, 02:08 AM
72-149's Avatar
im useing internet explorer & still cant see prices
Old 01-02-2012, 11:41 AM
I found the answer to that issue last night with one of my other computers. It had the newest IE9 installed on it and it would not show anything on that page either. All my other computers have IE8 and it works fine with them. I uninstalled the IE9 and restarted the PC which will load the prior IE8 back. It worked like a dream after that. So uninstall your current version of IE and restart your computer. You should be good to go.
Old 01-02-2012, 08:54 PM
Mountain Heritage's Avatar
DX3....
Use your extra cash to buy CUBS, not computers!! Only need one PC to read what is on the web anymore! Heck if your that dialed into websites, get a 2nd monitor.
Mike
Ontario, Canada
Now everyone wants a Cub!
Beware of the Wife
Old 01-02-2012, 09:25 PM
Originally Posted by Mountain Heritage View Post
DX3....
LOL, I pick up old pc's from clients and refurbish them. I end up with too much junk usually.
Old 02-22-2012, 04:42 PM
lnelson lnelson is offline
My 982 did that exact thing once a few years ago. I replaced the condenser on the points and it has run ever since.
Old 02-23-2012, 05:54 PM
cub123's Avatar
cub123 cub123 is offline
Also if you don't already, you need to run gas with a minimum of 91 octane or it will knock/surge. I had issues with surging, read my manual and it said to run 91, cured it
Old 04-23-2012, 09:02 PM
cubpsycho cubpsycho is offline
Hi i will tell you, check that points cover my long screw had been tight i had to loosen because it was ground out, and now and thenwould misfire, and or skip, i had to move cover for it to get full power back. but if you tighten it to much, you have to take the cover off and bang the cove hole back out, the other is definetly right the points wire underneath is the second, but i guarantee its one of them!!!!!!!!!!!!!
