Old 01-05-2012, 04:38 PM
Combination of wheel weights, washer fluid in tires, and chains. When I had my 128 I used 8.50s instead of 10.50s and I had better traction. If you really want traction, chain up some 6-12s and throw 150-200# of wheel weights on them. The problem with wider tires is that they float over the snow and ice instead of digging in, which is why I've never understood people's desire to install the largest, widest possible tires they can on these tractors. They are of no benefit unless you're driving through a mud pit or the extra width is needed for stability. Otherwise, narrower is better, although 6-12 rears look pretty dumb on anything WF on up, IMO.
Old 01-05-2012, 04:57 PM
krhoover krhoover is offline
Ok, I guess I'll give those narrow tires on that parts tractor a try. I don't mind looking dumb if I can get traction to get thru the snow. I'm going to have to do something about weight though.
Old 01-19-2012, 08:26 PM
A little update on snow plowing with my 1450. I filled the tires with WWF. I got 61/2 gal in each wheel. It made a big difference on how much better the traction was. Have used it twice since doing it. We got another 5" today and had no trouble at all. Now when I go thru the yard to the the dog kennels, if I don't pay attention, I doze the ground, where before I would just stop and spin. I have also made a bracket with a 1" allthread (like one I saw on here) to put another 50lbs of barbell weights or so on each wheel. Hope to get that set up this weekend. Thanks to all for the ideas I get off of here.
Old 01-19-2012, 10:25 PM
Glad you got the 1450 going, and had fun in the snow.
Old 01-20-2012, 05:57 AM
72-149's Avatar
72-149 72-149 is offline
You need weights if you don't have any...I have 300# on the back of my snow removal tractor.
hay matt what do you think a set of 26x12x12 true powers on 12x10.50 rims weigh ea. just tire & rim & tube .just woundering .thanks
Old 01-20-2012, 06:37 AM
I haven't a clue...40 or 50# each, maybe.
Old 01-20-2012, 11:22 AM
ndanger ndanger is offline
Default WWF in tires
How do you get the WWF in the tires http://www.onlycubcadets.net/forum/i...s/bigthink.gif (if this is a dumb question, I apologize; still, I can't think of any way other than pouring it in through the valve stems and then re-installing the valves and inflating the tire, which seems ... somehow wrong... to me).
Cheers,
Dave
1976 1250 Quiet Line/44" Mower Deck
1976 1650 Quiet Line/50" Mower Deck/42" IH Blade
Agri-Fab Utility Cart
Old 01-20-2012, 11:25 AM
cub123's Avatar
cub123 cub123 is offline
If you go tubeless you can pop the bead on one side and pour it in, if you run tubes you can get a tool to put it in through the valve stem. I think TSC sells them.
Old 01-20-2012, 12:04 PM
Mortgaged Mortgaged is offline
For filling the tires, look for the Slime products display at your local Wal-Mart, etc. as they sell a $5 tool that allows you to fill their product through the valve stem. It's not fast, but works fine.
184, 1450, & 100. Unfortunately, not enough space to keep more!
John - Grand Rapids, MI
Old 01-20-2012, 01:20 PM
Thanks. I'm going to try that.
Cheers,
Dave
