Old 11-03-2013, 09:11 AM
Thanks for the update! Looking good!
X2!
Old 11-07-2013, 02:07 PM
FarmFresh's Avatar
Default Finished the exhaust stack
I built the stack with a muffler inside, because this engine is really loud without. I used a 3.5" elbow, a thrush muffler/glasspack, and some 3.5" tubing. I had to notch the elbow to clear the hood ( did not want to cut the hood). I am going to add a stainless piece between the stack and the hood to act as a heat shield. I am also going to build a support brace for the stack. I one pic you can see how the air cleaner will sit. I wanted it out of the hood, for space reasons, it looks like a big tractor and I did not want to fill the original fuel cap hole.
I know it looks big but with me on it (6'4") and the 26/12-12 Ag tires, it will look a little more proportional.
149 Raised Bed Tractor
1512 Being restored
1450 Missing its heart
Original 1961 Red No options
782D Missing Engine
Old 11-07-2013, 02:36 PM
Nice job!
Old 11-07-2013, 09:25 PM
Originally Posted by FarmFresh View Post
I spent today adding power steering to my 1810 Diesel project. I used power steering parts from a JD318 and modified them to fit the cub. Space is very limited with the large Kubota engine so it took a ton of cutting and welding to make it all fit. I had to remove 3 inches out of the steering column and that was a fun task. Then it took a while to get the spindle and cylinder geometry figured out and to get the spindle reinforced, but now just a few lines and it will be moving and steering. I did not take any pics during but here is a few when it was done. I raised the column a bit over stock, but with the air ride seat it is super comfortable (especially since i'm 6'4" tall). Hopefully I can get the hydraulic lines and the foot hydro controls built this week.
Does the tire rub the cylinder on a hard left turn? mine did when I used a Deere cylinder
Old 11-07-2013, 10:00 PM
FarmFresh's Avatar
No, I cut the arm off the spindle where the cylinder attaches and I moved it so it is parallel to the axle instead of in front of it. (if that makes sense.)
1512 Being restored
782D Missing Engine
Old 11-09-2013, 06:45 AM
yes I understand what you are saying.
If I had used a smaller diameter cyl. barrel (IE Cub) it would of cleared.
But I used what I had.
So I just built extended axle stubs moving the tires farther out
( wider stance) and solved the problem on my 782.
Thank you for the reply.
Old 11-11-2013, 08:28 PM
Driver4_life Driver4_life is offline
What was the cost of the engine swap and what all engines would work on a 1863 model I would love a diesel on mine
Old 11-12-2013, 01:22 PM
FarmFresh's Avatar
I have no idea on cost, I'm just using what I have. You can use any engine, that you can make fit.
1512 Being restored
782D Missing Engine
Old 11-15-2013, 05:20 PM
FarmFresh's Avatar
Got my hood sides installed, and everything clears. I also picked up some 26/12-12 Carlisle tru powers that I will install once I find a set of 12"x10.5" wheels.
1512 Being restored
782D Missing Engine
Old 11-15-2013, 10:10 PM
Very nice!
