Old 01-24-2012, 02:27 PM
guess what you have to do to change that S/G belt?
Old 01-24-2012, 03:27 PM
cub123's Avatar
cub123 cub123 is offline
The pull starts are cool! I would just pull the S/G and use the pull start, Because I don't think the S/G Is going to have the guts to turn it over on the small pulley.
Old 01-24-2012, 03:54 PM
cub71 cub71 is offline
I dont mind hand starting it, and I would just assume have it with just the recoil. how do I find a schematic for mine with just the recoil. And _DX3_ I do see what has to be done to get the belt off but since I'm going to only use the pull start then I plan on just cutting the belt off.
Old 01-24-2012, 06:06 PM
What a crazy setup.
Do you know if the old spark plug wire that comes out from behind the blowers housing is still there?
Old 01-24-2012, 06:19 PM
yeah the old one is still there and there is also two other wires that come out with it. I also dont no if I can use the recoil because it does not grab the inside of the pully anymore to start it, the metal is worn down to much so now I'm trying to get it running with the S/G but now i think that I have a bad ignision coil, because I can't get any reading on my multimeter when i put it into the coil.
Old 01-24-2012, 07:39 PM
mmzullo mmzullo is offline
There is a company that still sells the dogs for the pull start. But the drive cup should also be replaced. I have a 3 digit pull start O that would start on the first pull. But I haven't run in in a couple years. I'll see if I can find a part # for ya.
Old 01-24-2012, 07:50 PM
The other two wires are for the ignition switch.The original coil behind the fly wheel may be bad,do you still have spark on the unused plug wire?The drive cup and dogs are out there.good luck.
Old 01-24-2012, 08:18 PM
I'm not sure if this is it but here ya go. http://www.google.com/products/catal...ed=0CEoQ8wIwAA
Old 01-24-2012, 08:45 PM
if the unused spark plug lead still has spark, then can I use that with the S/G?
Old 01-24-2012, 09:32 PM
I don't think so,It is either one or the other.The coil under the blower housing is controlled by the points to fire the spark plug.the way it is now,the points control the exterior coil,getting power from the battery.somtin like that.
