Old 03-23-2009, 04:54 PM
Originally Posted by young enthusiest View Post
Ok, if your lever has zero movment (no play at all in the linkage) I can't help you. if it has a little movment, like the amount expected from a 35 year old linkage, pull the gas tank, and the hood support that are mounted to the dash. you should see all the linkage. put some PB blaster or whatever you use, on the actual valve rod. to the best of my knowledge this sticks out the top of the valve housing. hey, while your down there you could check the PTO switch, and all the wiring associated. I am probably barking up the wrong tree thinking the valve itself might be froze. but I think it might be worth a shot
He's right. The plunger likes to stick in the valve body. Some oil or PB blaster and a couple of taps with a hammer and you should be back in business.
Old 03-23-2009, 09:20 PM
Eagle Keeper's Avatar
Eagle Keeper Eagle Keeper is offline
Wow the find of the year so far !!! Very nice. Haven't come across a deal like that since I found a Robby Space Patrol for 95 bucks. The valve will free up.
