![]() Quote:
As I have been trying to explain to you. The tabs either need to be removed or the axle itself needs to be relieved. The axle will not fit in the channel if one of these options is not performed. No way around it. If you remove the tabs you could weld them back on-on the outside of the channel. Or you can leave them alone and relieve the axle to make room for them. I chose to relieve the axle. This option was easy for me to do because I have access to the machines. It also allowed me to keep the axle snubbers functional.
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
