DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
Here is a simple way to fix a sloppy trunion if you can't or do not want to weld up the bracket.
I used 3/4" round stock x 1/2" long. Bore a .375 diameter hole .415 deep to make a pair of "Caps" for a single spring that is approximately the same force as the stronger of the 2 stock springs. I did this to my 149, my brothers 129 - both workers (grass & snow) with great results. Anyone else tried something like this before? John |
so i took off the fenders and seat. pushed the drive lever all the way forward which brought the trunion all the way back just clearing the tunnel. giving me enough room to weld. havent welded it yet. but i plan on doing the same thing, using a cold rag and just doing a little spot welding to fill the gaps.
Looks like a good fix.
the two valves on top of the hydro with the push buttons which is actuated by a little flapper on the tow-drive lever. what keeps those pushed done instead of holding the lever with my hand in the tow position?
thanx for the pic. that ittle tab is there but the lever does not go down that far. but it does push the buttons down. i will have to look at it again. something may be pushed or bent in the wrong direction.
Can you get a pic of your lever and the tab. Both pushing and not pushing on the buttons? I don't have a hydro that uses the lever or I would get you some pics.
yeh, will do
first two pics are in drive and second two are tow
i think someone prior forced the lever too hard in drive and bent the tab/flapper attached to the lever. see how the lever travels way above the drive sticker and wont even go down to the tow sticker. whatcha think? |
