![]() Quote:
I used a pair of "bushings" on the inside of the pipe because I didn't want to cut slits in it. That only allows for exhaust leaks, soot and whatnot. This way, it seals tightly around the first pipe and doesn't weigh a lot or look too clunky. I have to trim the threaded sections of the clamp yet. It squeezes down tight enough on the outer pipe just enough that it seals it and secures it. Again, light, but it works and doesn't look too bad. There are two types of drain pipe. One has a flange where the nut slides over the pipe (which is what I used) and secures it with the flange. The other type would have threads on the area where I've got the clamp, where a pipe would go inside of it and the nut threads onto the pipe in the area where I've got the clamp. To keep it clean, the pipe with the flange is the way to go, IMHO. |
Nice score on your good looking O!
![]() Quote:
Just for giggles today, I decided to do some pricing for some items that I would like for my new Cub. I went to Cub Cadet's site and started clicking away. Keeping in mind that there were only seven items in my cart. Here's the list:
spark plug wire battery retainer strip regulator fuel tank key shifter knob flex coupling disc (end of driveshaft disc) At $393.18 (subtotal), the cost of those SEVEN (7) items cost MORE than the TRACTOR that I purchased!!!! ![]() I know, don't buy into something and then complain about the cost. And really, I'm not. Well, okay, I AM but only as a point of interest. I'm not really perterbed about it because I'll find these parts in time, or figure out a way to eventually replace them. The fuel tank and the regulator wound up the most money and I already bought one closer to home for about half of what they're asking. Quick, Cheap or Good -- pick two. I rarely go for "quick". ![]() Still liking that little tractor! |
![]() Quote:
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
![]() Quote:
By the way, that red 'O' above is of the chain. I would love to see more pics and here a little more about it. T'would be nice to have that kind of budget! |
![]() Quote:
That is true DX3. I'll have to check out some of the sponsors for some of the items. There's just a few little things that really should get some attention. I'll start there. And, your point is well taken that once they are gone through, they're many times better quality than what the big-box stores carry. And, might I add, more fun too! That's why we've got the 1715 AND the Original. |
Been working on the Original a little bit. Fixing little things that were left undone when the previous owner had it.
I did some body work on the hood and filled in the gaping hole that someone cut in it for whatever reason. They also tried to fill in the hole that was cut for a gas tank (?) at one time. I think it looks a lot better. Painted it white instead of off-white. I like it. First pic is how I received it. After that is how it looks now. Not sure if the difference shows through in pix but, it LOOKS a LOT better in person. |
And another
Really good looking "O". Ours has a long way to go before looking that good.
Tags |
cadet, cub original |
