Old 03-26-2012, 10:24 PM
Dave01's Avatar
Dave01 Dave01 is offline
Thanks guys, yeah I do love the old ones BUT till ya give a super a try you just don't know the feeling.
And Dave we bought the 2086 with the IH sticker already on the tractor and I just can't find the heart to remove it.
I'm with you, no need to remove it! I have to tell you I keep looking at that picture. Who is on the 2084?
Are you guys running any weight on the back of the tractor?
1864 w/48" deck, 2084 w/54" deck + 54" blade, 3204 w/48" deck
Old 03-26-2012, 10:50 PM
EricR's Avatar
EricR EricR is offline
PaulS is on the 2084-(He is my Father) and yes, his has the 75lb cub weights and the 2086 has 100 pounds of homemade concrete weights made by him and I. Some day when I get a little more time I will do a write up of how he and I went through the process. Thanks.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 03-26-2012, 11:48 PM
Dave01's Avatar
That's great Eric and Paul, you guys almost have a matched set. I'd be curious for your opinion on the Kohler vs. Kawasaki since you get to run them side by side.
I saw the wheel weights, wondered if you needed any weight out back, sounds like it's fine without it. I have a steel box bolted in back that I put some steel weight into, balances my blade very well, plus I also have 75# wheel weights and chains like your setup.
Old 12-08-2021, 09:28 PM
Farmall450's Avatar
Thanks Paul, great info. There must be some reason they built the 2 different models, I wonder if the 551 has a bigger auger and requires more HP. As I keep up my search I want to make sure I get the right model for the 2 tractors.
Both are listed to fit my 2182, so must be a minor change improvement.
I think the 1811 is going to lose the deck and get the 450 blower year round. 1711 has a sleeve hitch, so more useful for rear mounted attachments.
