Old 04-09-2012, 09:41 PM
Mcamp Mcamp is offline
You should also check the sending unit for the oil light and the remote oil filter lines for leaks.
Old 04-09-2012, 10:21 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
I did, it does not have a sending unit installed. its pluged, and not leaking.
I found a pressure gauge kit for it I want to someday get for it.
Doug
Original , 100 , 125 , 582
Old 05-12-2012, 11:15 PM
ole 147 ole 147 is offline
Oil burns bluish
lets hope not, the oil was just below the full mark when I started to use the plow. saw some drips this morning and checked the dip stick its a little below half now. and it was smoking under a load, but thought it was just burning to rich of gas.
oil burns white gas blackish right?
no clue. I did let it run for a few and then at high rpm held my hand above the carb. I got a fine mist of oil on my hand.
