How much for the rear plus shipping? cc1450
There are parts manuals out there. I ordered one from BinderBooks.com and am pretty pleased with it - just be sure you've got a 3-ring binder to put the pages in; they come in looseleaf.
I believe the bolts are 3/8" and length depends on which side they go on, as the axle tubes are different thicknesses. I have an aluminum rear end and the same bolt holes for the front supports are broken out. I put a CI rear in my 982 and used all of the Aluminum parts - worked pretty slick. I think mine was from a 125. If you want to use the larger disc brake calipers, you will need to change the axles out. Also, you can't just change the axles - you have to change the entire carrier. I checked that box. ![]() Good luck! Can't wait to see some pictures of your 1572.
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
I just went through replacing the broken bolts in my 2072 rear end. You can see my thread and a picture of the bolts here on the forum. I got help and we welded a washer and nut onto the bolts and they unthreaded easily took maybe 10 minutes tops. Mine were not wallowed out so I did not replace the aluminum case.
Don Smith https://www.facebook.com/SouthernKentuckyCubCadetClub IH 982D aka "The Big Red Smoker" BRS w/3pt hitch CC 1572 aka "The Big Yellow Smoker" BYS w/3pt hitch-PTO Brinly Cat 0 3pt plow-Brinly sleeve hitch plow Custom Hydraulic lift disc-Haban Blade-Brinly Cultivators Cub Cadet lawn trailer and lawn sweeper |
These cast iron rear ends are pretty heavy. I would hate to see what shipping would run you. There are tons of them out there. Even if you had to buy a whole tractor in rough shape for a couple hundred bucks to get one you would be better off than shipping one.
![]() -Mark 1978 1450 1976 1450 |
