Old 03-31-2012, 11:55 AM
Originally Posted by fixitalldad View Post
What I don't get I guess is that terminal 'A' has a reading to ground (the case of the s/r). Should it be this way?
IIRR the internal wiring causes it to SEEM Grounded.
Without going into my old books I don't have a schematic on hand to post/show you.
You have to remember the Armature has HUGE Gauge wire compared to the field wires
Does it charge/operate correctly? if so, let it be and just "believe" Ha.LOL!
Old 04-01-2012, 09:04 AM
If the armature was, in fact, shorted, you'd see smoke, the S/G would get hot, and it wouldn't spin the engine over.
Old 04-01-2012, 02:02 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default Ohms
"Before you said 1 ohm of resistance, and now you're saying zero...which is it? 1 ohm is probably about right. "
Measuring very low resistances with a 2 wire measurement (like a VOM does) is pretty pointless... and generally not repeatable even with a good meter (I use a Fluke 87).
What do you measure at the battery terminals when the motor is running?
Are you sure you're not on the AC range when you're seeing the high voltage reading? There's no way I can see of getting high voltage out of a S/G operating at normal RPM range.
I'm thinking measurement error , not equipment (S/G) error.
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 04-16-2012, 09:20 PM
fixitalldad fixitalldad is offline
Ok I checked things over and ordered a new voltage regulator and things are much better. I also found out that DVM that I always use, would spaz out when it got close to the tractor when it was running. Switched to my back up meter from radio shack, and had no problem reading the voltages. Sorry I took so long to reply but I have been busy cutting up and splitting my truck load of (9 cords) wood. Just have a little left to split. Thanks guys for all of your help!!!
Old 04-17-2012, 06:44 AM
jbrewer's Avatar
Default Great.
Good to hear it came out well.
I've seen the "dancing readings" with a cheap Harbor Freight toolbox DMM too. I should drag my O'scope down to the garage and see what the charge line looks like some day.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
