So i mowed again today after charging the battery and the pto quit again right away. I check voltage at high RPM and am getting about 13.5 volts. I then bypassed the seat switch and still no luck, pto would not engage. I then checked continuity on the jumper the PO installed to bypass the reverse switch and that checked good. I then ran a wire directly from the battery to the pto connector and it works perfectly with out ever stopping so i got the lawn finished. That said I'm thinking it is in the pto switch, unless there is some other component i have over looked. i tried to check the pto switch for continuity but not sure what terminal does what, anyone know or have you ever disassembled the pto switch to repair? I really don't want to spend 50 bucks on a new switch if I don't have to. Thanks
Cub 1810 Cub 147 with QA-42 snow thrower and soft cab Cub 100 |
There is a relay on the left hand side of the dash tower that might be acting up - I think that it has something to do with the safety interlocks, but I can't recall. Wiring diagram would show it, though. I had to put a new one on mine when I first got it - the PTO would work if you held it in the "start" position, but wouldn't stay engaged once you let it back into the "run" position.
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
