Old 04-01-2012, 10:05 PM
Originally Posted by brentwd View Post
You can lose the coulter or add some weight to the plow. Do the plow setup thats on this sight. If you don't have weight on the back of the plow, the coulter will not let the plow pull in. After looking at your first pic you need to adjust the point of the plow up and move your coulter about 1 inch from the plow. Hope this helps
BS. I've not had trouble getting the plow to go in with the coulter on and no weight, although it would help in something like a rock-hard no-till northern IL field.
Old 04-01-2012, 11:15 PM
You have something bad wrong with your setup if you can't get your plow in the ground without weights. Weights are not needed.
See Vid:
Click on Pic for Video
Old 04-02-2012, 12:28 PM
mmzullo mmzullo is offline
You dont need any weight on the plow if it's set up right. The plow should pull itself into the ground. If you have virgin soil or clay soil maybe. But at Riverside you dont need weight on the plow. I plow with a 70 and 10 inch plow with no problems of getting the plow set in the ground. You dont even need front weight.
Old 04-09-2012, 06:03 PM
flood flood is offline
Default Thanks again for your help!
Just wanted to give an update on my plowing education. (You saw the results of my first pitiful attempt) Made some adjustments, and wow - too much fun! I was so impressed by the way that old 14 HP Kohler tore through the sod.
Cub Cadet 147, 149, front blade, brinley plow and cultivator, QA36A snowthrower
Old 04-09-2012, 09:15 PM
Looks like you had a great time plowing.
Old 04-09-2012, 09:29 PM
Awesome pic too!
Old 04-09-2012, 10:12 PM
EricR's Avatar
EricR EricR is offline
Very good there Flood.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 04-09-2012, 10:19 PM
Now that is much better. Glad you got it figured out.
