Old 04-10-2012, 12:34 PM
Glad you got it figured out, and not getting shocked anymore.
Glad you got it fixed too bad no more shocks to keep you on your toes.
Old 05-12-2012, 08:20 AM
french french is offline
Smile Wiring Diagram
I need a wiring diagram. I have a Cub Cadet 2135. Bought new approx. 1993. Can't find the serial number on it. There's a tag under the hood but all the writing is worn off. I need a wiring diagram to put in a new switch. Any help would be greatly appreciated!
Old 05-12-2012, 08:49 AM
Need the following -
There are three (3) different diagrams for the 2135 depending on serial number range. What is your chassis serial number..??
Old 05-13-2013, 07:08 AM
slo793's Avatar
slo793 slo793 is offline
Default Need wire diagram for 2135
Hello, I'm new here but had a cub cadet 2135 for some time now. I recently came into the problem of the key not turning off the engine. I have searched for a solution but have not had time to try anything yet. I found this post and was hoping I could get a wiring diagram for it. My serial number is 251471. Any help on this or my problem would be greatly appriciated.
Old 05-13-2013, 07:20 AM
Diagram sent to the E-Mail address listed in your profile.
Old 05-13-2013, 07:25 AM
slo793's Avatar
I got it. Thanks for the help. I am going to try to find my problem later today.
Old 05-14-2013, 07:20 AM
slo793's Avatar
Found my problem and fixed it. The yellow grounding wire had pulled out of the connector near the magnito. Took it apart, cleaned it, and pushed the wire back into the connector. Now it turns off like it should. Thanks for the help.
Eric Slovinsky
CC Model: LT 2135
Old 05-14-2013, 01:13 PM
Great news! Glad you got it fixed!
