Old 06-24-2014, 05:45 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
Originally Posted by moparman849 View Post
First off the k301 is the best 12 horse you can buy because you can bore a lot off the cylinder walls
Not really
Old 06-24-2014, 05:49 PM
dvogtvpe's Avatar
Originally Posted by Cub 128 View Post
I measured my bore and it is at 3.376" or 85.7504 mm, and I was going to get a new piston and rod but they don't look bad at all there was barely any carbon build up? but I do want to replace the rings just for good measures.
So can I just use a balled flex hone to get some cross hatches on the wall, or should I spend the extra money and get a new piston and bore it .010 over?
if the bore don't look that bad I'd leave it since if you ball hone it and put new rings in it'll take a long time to seal up again. remember you still have a worn bore. a ball hone just follows the contour of the cylinder. now you have a out of shape bore with round rings. now myself I would worry about the rod.
Old 06-25-2014, 08:39 AM
stihltech stihltech is offline
Originally Posted by dbuck View Post
Should not a 128 be gear driven to start with? Also why is the starter pulley on the flywheel side?
The model and spec of this engine originally was built for TORO not Cub Cadet that is why it has the belt drive pulley on the flywheel side. I would only think someone mixed and matched parts. A hydro into the gear drive frame and an engine from another brand. That would explain the homemade driveshaft.
Old 06-26-2014, 07:55 AM
dbuck dbuck is offline
Smile
Thank you for explaining that.
Don B, USAF 1962-1968, Ft. Wayne, IN
