Old 05-13-2012, 03:45 PM
That's great! Glad you got your cub going!
Old 05-14-2012, 11:05 AM
VIOLATOR VIOLATOR is offline
Okay so It looks like I have spoken too soon. I was cutting the grass today and about 5 min in to it the tractor died. NO SPARK once again. I pushed it back in to the garage and tinkered with it for just a few min. I checked the points and they looked good and I did a quick look over the wires and they looked good. I am going to try and take a better look at it tonight once my son goes to sleep for the night. Any ideas on whats going on or what might be blown and why. I am banging my head against the wall with this one.
Old 05-15-2012, 12:00 AM
bkw3614 bkw3614 is offline
Steve,
Thank you sop much for those wiring diagrams and diagnostic advice. My 1250 does not charge and I don't want to buy a regulator unless it is bad. With these diagrams, I can trace a bit.
Brian Wittman
Old 05-15-2012, 06:10 AM
steveyrock's Avatar
steveyrock steveyrock is offline
wow,sorry to hear your still having a problem.
I would check out the ignition switch if your sure the wires and connections to everything are good.Must be loseing the connection from the switch to the positive side of the coil at times when the switch is in the run position.
Your grounds are all good I assume? none of them can vibrate and get disconnected?
122-snow blade and 42 deck, wheel weights, fluid filled tires,chains
106-42"deck
1250-44 and 50" decks
147-44"deck
2155-42"snowblower 38"deck, chains,suitcase weights
Exmark Quest-zero turn 42"deck 23hp Kawasaki engine
Old 05-15-2012, 06:15 AM
Run a wire from the battery directly to the coil to "test" all the ignition wiring.
I had a tractor with an intermittent ignition switch, this was my easy way to diagnose it.
Old 05-15-2012, 09:54 PM
So good news today I found the lose like thanks to the advice I got about jumping the coil. I found the lose wire, It past me due to it being in a plastic case and having two wires in it but only one was lose. so I hopefully this will be the last of the issues. here is a picture of the lose connection. and the finished product.
Old 05-15-2012, 10:18 PM
Great news! Glad you got it fixed.
Old 05-15-2012, 11:47 PM
Same here! Time for a now!
