Old 04-28-2012, 02:24 PM
Draphty Draphty is offline
Sounds good...that's what I'll do.
Thanks...Draphty
Old 04-30-2012, 09:36 AM
I actually got to drive the Cub for the first time on Saturday. It was short lived due to a fuel delivery problem. I pulled the tank and found the shut-off valves almost completely rusted closed, the grommets attached to the tank in very poor shape.. So, I have some more parts to order...but it's getting there!
Thanks again for the help!
Old 04-30-2012, 09:58 AM
Take the valaves apart and clean them out, replace the two bungs that go into the tank and replace all of the fuel line and I do mean all of the fuel line. Oh and change the fuel filter. The gas eats the old stuff.
Old 05-01-2012, 10:55 AM
More good advice...I ordered the grommets and I'll pick up locally new fuel line. Before I saw your post, I tried to order new shut off valves...no luck, can't get them anymore. I'll see if I can pull them and clean them out.
Draphty
Old 05-01-2012, 11:03 AM
Draphty
Our sponsors will probably have the shut off valve available. Try calling or emailing them.
Old 05-01-2012, 11:48 AM
Draphty
You should be able to take them apart and clean them out with a drill bit. I may have a couple in the barn, I'll have to look.
