Old 04-30-2012, 04:53 PM
IH weights are not very space-efficient; they take up tons of room and only weigh 26 lbs. There are countless other brands of iron weights that weigh 50+ lbs each and fit inside the rim better.
Weights are great, BUT, I am convinced the 1X8 I had gave me clutch difficulties because of the loaded tires.
The 14HP K321 would just overpower the clutch!!
A new clutch with a slightly stronger than stock spring is necessary if you expect to put 14+hp to the ground. My 582 with 18 hp and a stock clutch (other than the spring) will not slip the clutch in any gear and with 250 lbs of weight on the wheels.
Old 04-30-2012, 07:19 PM
Donovan M.'s Avatar
The 100VTR has plastic wights on it with two 25# on the inside and the plastir ones are all steel in side.
Donovan:
62' Original-fenders
Old 04-30-2012, 07:20 PM
Donovan M.'s Avatar
I love the 75 pounders.
Donovan:
