Old 05-04-2012, 10:55 AM
Originally Posted by wj-ihc View Post
Do most of you guys use your hold downs and do they seem to keep the hood from shaking and rattling on your 1x8/1x9 series tractors? I have taken them off of a couple of mine because I have had issues with them catching on the hood when raising and lowering. I may need to make some adjustments to my grill in order to properly position the hood with respect to the dash, and I know I need to do some fiberglass work on the dashes to tighen fhings up.
I do prefer to use my hold downs. In case you weren't aware of it, you can do a bit of adjustment up and down on the fiberglass housing mount to help create the right fit. Also there should be I think 4 rubber strips that mount to the steel frame the hood sits down on. These are factory and should help reduce vibrations. Some people also use seat cover edging "identical to what holds your factory seat cover to the shell" on the lip of the hood to help with vibrations.
Old 05-05-2012, 02:07 AM
westofb's Avatar
westofb westofb is offline
When I rebuilt my 149, I really hated the way the hood mounted, the PTO side latch would interfer/ get tangled up in the PTO handle/ mounting plate. I replaced my hood with one from a 1450 quiet line. It is exactly the same hood, just have to get the latch from the dash tower as well, seems to be a lot better idea for holding the hood closed in my eyes....no silly interferring latches to mess with!
Jeff
Brookfield, MO
________________
Old 05-06-2012, 09:26 AM
dbuck dbuck is offline
Thumbs up
Hood brace repaired. Rattle gone. Thank you everybody for your replies. Don B.
Old 05-06-2012, 12:59 PM
Awesome news!
Old 05-06-2012, 10:00 PM
Glad you got it fixed!
