Old 05-11-2012, 09:12 AM
jbrewer's Avatar
jbrewer jbrewer is offline
On the above diagram, there is nothing noted about needing a separate Neutral for the 230V application.
True... probably because it's NOT new, and is made in China, and there are more exceptions allowed (by NEC?)
The 4 wire arrangement is the same philosophy as the 3 wire 120V, where neutral and ground are connected together only at the load center....
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 05-11-2012, 07:33 PM
I think most modern 230V items have the ground and neutral tied together ONLY at the panel ...meaning a 4 lug plug but yes, this is the way to use what you have.
John
My four year old Hobart Handler 187 has a 3 prong plug. Two hots and the ground.
Old 05-12-2012, 08:41 AM
You don't need a neutral unless there is something that uses 120 volts inside.
Old 05-13-2012, 02:57 PM
jbrewer's Avatar
Or unless it's an "appliance" and you care about wiring to Code.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 05-14-2012, 12:38 AM
jdroison jdroison is offline
Thumbs up ground and neutral
the only diff between ground and neutral is ground is not to be used as a current carrying conductor, it is only for safety. if a unit operates on 220 but has circuits in it that only draw 110 off of one side you must have the neutral to carry the current for the 110 portion. also in this case the neutral should not be bonded to the equipment chassis even tho neutral and ground end up the same in the panel. and true there is a lot of equipment that don't follow these rules.
