Did a little more work on the 60” Haban deck today. The rear mounting bracket had a couple cracks in it and had been poorly welded in the past by the PO. Removed the bracket straightened it, ground out the broken welds, re-welded it and added a couple reinforcement plates to it. I didn’t like the way it was designed, the way it was as the tractor pulled it forward or lifted it would cause the bracket to try to bend forward. I think this is why it cracked in the first place. Two 4” X 4” X ¼” plates, a little welding and four 3/8” bolts later and I’m pretty sure that problem is solved. Pulled the rear wheels, cleaned the bearings, greased the whole thing, tomorrow I hope to hang it under the 2182 and kill some grass with it.
Great job, Sam! Please post some pics of the super mowing.
Nice work!
Used the Haban deck easy install tool today. Anyone that has installed one of these older style Habans knows how much fun it can be. This tool works awesome. First you position the Haban deck behind the tractor, then you attach the Haban easy install tool, lift the tractor, roll the deck under the tractor, lower the tractor and attach the deck to the lift. Install the belt and go kill grass.
Now I know what I was doing wrong, I thought you were supposed to lift FOUR wheels off the ground!!
![]() ![]() ![]() I got my Haban 60" sitting in the shed waiting for the day I Cub Cadet cut grass again!!
Great pics, Sam. Looks like the Kubota comes in handy for ya.
I love the Cubs but I don't know what I would do around here without the little Bota.
