I think we have an idea to make an adapter to mount the cat "1" center link to the tractor without cutting either the original tractor mounts or the center link.
stay tuned, we'll see how this plays out..
Loving the 1772, wish I had one let alone one that nice!
Josh 1989 SGT 2072 (restored) 60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake Cub 128 with creeper and rear PTO with reverser(next project) IH built 682 and 782 that will combine to make one |
There is a long version of the cat0 top link out there. I seen them for sale when I was buying my top link for the 1864.
Thanks for all the input so far. I found an operators manual and am anxious to read it when I get a chance. It has info on tiller mount adjustment.
Does anyone know how to drain the oil out of the gearbox? I looked quickly last night, but didnt notice any drain plugs. |
I agree with everyone else. Sweet tiller pics!!!
The left (when looking from the rear) 3 point arm does look backwards. Swap that around. I also agree with IowaFarmboy. Pull the extensions off the lower arms of the tiller and hook directly onto the tiller. That might help the Cat O toplink work. Some implements were Cat O or Cat 1. Adding an extension would be the different between the two Cats. Sure am jealous you found that gem.
Josh Diesel Cub Cadets........... |
Thanks again for all the input! I think we are going to try an adapter plate to mount on the tractor and go from there. If I pull the tiller closer, I will definitely have to cut the PTO shaft. I might have to cut a couple inches as it is.
Not to bore anyone, A few might know the story behind the 1772. This tractor has been a blessing in disguise to me. The Cub is technically my mothers. My father bought it a couple years old, from the original owner during his divorce. (he still wants to buy it back someday) Unfortunately, my dad passed away 4 years ago. I use the Cub weekly to mow my mothers yard. At first it was "just" a way to keep me from trailering my mower to her house. This spring while changing oil on the 1772(and after tilling our garden with a walk behind) it hit me to start looking for a 3pt tiller. I have only been looking for a month or so. Last weekend at our daughters house in Milwaukee, I was checking CL before anyone else was up on sunday morning. The FIRST tiller that came up was this one! ( keep in mind I have been checking CL all month). It was only 10 minutes out of our way back home..so we made arrangemants to stop and look. After seeing it, we paid for it and had my son-in-law bring a truck to get it to a "safe" location. I ended up running back up there Monday afternoon to pick it up. (my wife wouldnt let me put it in the back of our Transport??? LOL) .. I do look forward to getting the little bugs worked out of the tiller. As for the 1772, I'm on the "first to buy" list....someday, when my mom moves to a smaller home, the Cub will find its home in my barn!
http://www.ebay.com/itm/TRACTOR-3-PO...item45ecf703f6 |
Making a new threaded end is what I did for my 982. You can also make a entire new link. The tractor end is only a heim joint and the adjuster is only a tube with 2 nuts welded to it. The heim joint end is short enough that you really don't want to be adjusting the top link by turning the tube anyway.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
Got a little time to work on the tiller mount tonight. First thing I did was turn the left lift arm around. Sure looks better from the back.
But, Looks like I will need to cut off about 3" of the PTO shaft. That was the main reason the tiller was being forced to the right. In one pic you can see the white soapstone mark where it will probably be cut. Next will be a trip to Farm & Fleet or TSC to see if I can find a longer cat "0" center link . Looks like I will have to pull the gearbox off the tiller to drain and flush it out. I do not see a drain plug. .......getting closer! |
