Old 05-28-2012, 08:57 AM
Compression testers are not very expensive. Also, if you take off the tinwork around the cylinder with the black plug, there will be oil coming out from between the head and the jug if the gasket is bad.
Old 05-28-2012, 08:36 PM
chip6990 chip6990 is offline
Its NOT a bad coil! It lit me up.then I was dumb enough to do our to the other side, yep, lit up again. Its getting spark and coil is definitely good. I pulled the plugs, both are a little black and sooty. I believe its a carb/gov issue. I ran it for bout 10 min mowing today, it never skipped a beat. Only doing it once its really hot I guess.
