Old 06-08-2012, 09:16 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
Yes, please tell us, Donovan!
Old 06-09-2012, 06:34 AM
gcbailey's Avatar
gcbailey gcbailey is offline
I fill through the valves too, little hand transfer pump with the fill kit from tractor supply, it comes with the "burp" valve that you have to do every so often.
Gary
Old 06-09-2012, 08:56 AM
Leadslingingdaddy's Avatar
Yep water hose with the fill kit from TSC and a gal of windshield wiper solution...
Old 06-09-2012, 09:13 AM
krhoover krhoover is offline
I used a drill pump made by Wayne. Someone said something about hooking the gal jug up to a hose and poking a hole in the bottom and blowing air into the jug. I'm not quite sure how they hooked a hose onto the jug, but I like that idea, sounds fast.
Old 06-09-2012, 10:01 AM
I use a drill powered pump that i got at the local hardware store.
This adapter fits the valve stem, the other end hooks to the garden hose.
I fill a 5 gallon bucket with the windshield washer fluid and have a hose from it the the pump. From the other side of the pump to the tire.
I have loaded 6 pair this way.
I put the valve stem at 12:00 oclock and keep filling till its just starting to come out. that leaves a little air space at the top for cushion.
Old 06-09-2012, 10:18 PM
bllwnkl's Avatar
Some say windshield washer fluid, others say RV antifreeze. What if you mixed the two?
Old 06-09-2012, 11:07 PM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
Duke, Does the Dawn change the freeze temp? I live in Southern KY and my cubs are always in a heated garage so Im thinking some part "something" and water solution would work fine. The BRS has beet juice but the 2072 doesnt have anything and I was thinking of adding something to my garden tiller also.
Don Smith
Old 06-10-2012, 01:31 AM
It doesn't allow the water to freeze. I don't know exactly how but it works for me. Beet juice is top of the line fill as it has a higher weight then anything else.
Old 06-10-2012, 07:52 AM
gcbailey's Avatar
I'd love to get ahold of some rimguard (beet juice) water is around 9lb/gal and rimguard is about 11.5lb/gal but the nearest dealer is like 250 miles from po-dank wv.
Gary
Old 06-10-2012, 10:22 AM
Donovan M.'s Avatar
I just use a drill pump a a big fast drill.
Donovan:
62' Original-fenders
