Old 06-22-2012, 11:41 PM
In order to mount the rod, one of the tips needs to be adjusted---sorry, I forget exactly how. I know since I had to use an electric lift rockshaft part for my hydraulic lift that I had to fabricate a rod that is 3/4" further out than the standard rod in order to make clearance. I use steel braided cable for and a set of U-bolts on some of my equipment, which tests to 750 lbs., and I believe it works quite well.
Old 06-23-2012, 12:04 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
does anyone made/sell a SEAL KIT for this pump?
Doug
Original , 100 , 125 , 582
Old 06-23-2012, 08:59 AM
mrcubcadet's Avatar
I bought my gaskets and o-rings from the Cub Cadet dealer. I will text you in a bit.
-105___ Tiller
Old 06-23-2012, 09:01 AM
mrcubcadet's Avatar
Yes it does!
-105___ Tiller
Old 06-23-2012, 10:19 AM
4SPEED's Avatar
Default More Pics, Pump Install
I used what was there after I cut the pull handle off. I think the pics show how I did it pretty good. what do you think...
once I got the 90* bend in it , I had to heat and twist the bracket (pic3)
I'll start on the retainer clip next. but really not needed. if I have a plow or blade on it , the weight will pull the lift bracket forward anyway.
I think this is a good mod if someone buys a pump and the PO doesnt give you all the parts. I dont think it looks too cobbed up..
Doug
Old 06-23-2012, 10:27 AM
mrcubcadet's Avatar
Looks pretty good, to me!
-105___ Tiller
Old 06-23-2012, 12:00 PM
4SPEED's Avatar
should I keep the Rat Rod Shifter look to the lift lever ?
Doug
Old 06-23-2012, 12:52 PM
mrcubcadet's Avatar
Looks good to me!
-105___ Tiller
Old 06-23-2012, 06:46 PM
Looks good Doug
Old 06-23-2012, 11:34 PM
Doug,
That is a good replacement on the lift bracket that you have done, but the rat rod look seems too long and bother some--so I would cut it back. I really liked your adjustable pin that you put in your lift--nice idea and forsight to make it adjustable.
