Old 07-05-2012, 09:05 PM
SharkyOhio's Avatar
SharkyOhio SharkyOhio is offline
Default Mule Drive belt on a 149
I've been mowing with a model 149 with a 38-inch deck for two seasons. Last time I ran the deck, the mule drive belt (IH-490489-R2), came off. It came off without breaking, so I re-installed it and finished mowing without incident.
Then when I took the tractor out to mow today, as soon as I engaged the PTO the belt came off; only this time it broke. I had a brand new spare belt (also an IH-490489-R2), so I installed it. I mowed a small area without incident, but when I disengaged the PTO, the belt broke again!
I checked the mule drive pulleys, deck alignment, everything checked out or at least seemed okay. I had done a lot of mowing with the first belt mentioned above, and never had any issues. The belts are not getting torn up or shredded; just breaking in half clean in one spot.
After losing two belts in short order today, I'm almost afraid to sacrifice another one without finding the cause. Does anyone have any suggestions for trouble shooting this problem?
Tractor #1--1972 Model 149 with rear lift
Tractor #2--1972 Model 149 with rear lift
1A tiller w/both extensions, 38" & 42" Mower Decks, Wheel Weights, Ohio Steel Fabricators 10" mold board plow, two 42" snow blades, QA-42A Snow Thrower, Brinly Sleeve Hitch
