Old 07-14-2012, 09:37 PM
John H John H is offline
I finishing tearing down the 149 today, and found the front axle was rubbing the bracket on the frame. And I bent both brake rods with the trans fell off the jack. The trunion is missing some of the bracket. Now the clear up start, here some pictuce.
Old 07-14-2012, 10:32 PM
Thanks for the pics and update.
Old 07-15-2012, 09:03 PM
jcsmith jcsmith is offline
Default cuts in axle
upon further analysis, it appears 1 of the mule drive pulleys caused the cuts in your axle. Mine did the same. I used JB Steel Stik to fill it in for aesthetic looks before paint. It looks like it happened to the axle channel as well. Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 07-15-2012, 10:12 PM
Ok thanks Chris
