Old 07-11-2012, 10:35 AM
Congrats and sorry to hear about the engine.
Old 07-11-2012, 11:16 AM
Sorry, to see that about your engine. Once you find an engine, you are really going enjoy your super!
Old 07-11-2012, 11:50 AM
SumBum's Avatar
SumBum SumBum is offline
It looks like the m20s uses the same block as the m18s. If that's correct I might be in luck and will be able to rebuild this one. I'm going to pull it out and tear it down later today and see what I'm going to need.
Old 07-11-2012, 04:20 PM
The case halves might be the same, but the crank, rods, pistons, and possibly the jugs are different between an M18 and an M20, if I remember correctly.
Old 07-11-2012, 05:03 PM
ajgross ajgross is offline
Inactive Member
Juggs and head are different too.
AJ
Old 07-11-2012, 05:25 PM
Darrell Darrell is offline
I would have still given the $350 for it even if it had a blown engine. Shop around for another tractor that has a good running Magnum in it. It may not show up quickly , but it will.
If you still didn't want it and you wasn't so far away , i would try to work a deal with you . But if you keep it and fix it , you won't be disappointed.
Old 07-11-2012, 06:12 PM
Leadslingingdaddy's Avatar
Many other types of tractors had the Mags in them....Just search the net and one will come up or check epay...Also, if you are not concerned about the originality of it you could repower with a Kohler Command....Lots of optionss no need it getting discouraged..
Old 07-11-2012, 07:28 PM
CubDieselFan's Avatar
You still got a good deal. The mower deck is worth the 350.
Old 07-11-2012, 09:00 PM
SumBum's Avatar
looks like I need 1 cylinder, cam, rod and piston and a governor gear. I'm going to bring the cases to a friend of mine and see if he can salvage them if not I can get both halves of an m18s for $80 that are in good shape.
I think the crank might have been spared. we'll see.
Old 07-11-2012, 09:31 PM
That looks ugly
