Solenoid bad or connection poles completely rusted up per your photo?
Merk, your ground looks to be a PO mod. Typically the ground is accomplished on the rear S/G chassis mounting bolt, instead of a separate wire. |
Yeah Im going to pick up a new solenoid at TSC today and a couple other things for it to, and then see what happens
Ok so I just put on the new solenoid and it cranked over fine with the key switch but now after like 5 min of me trying to start it ( not holding it on for more than 15 seconds and giving it breaks after) when I turn the key switch over nothing happens?
I can jump the solenoid with a screwdriver So do you guys think that I burnt this new solenoid out? or did the key switch go out? Why would the solenoid burn out in such a hurry if thats the problem? If it matters I bought the briggs 3 pole solenoid from TSC |
These solenoids are basically just mini electro magnets that pull a plunger into contact with the two main lead wires running to it. The smaller wire trails off to the key switch, and I'd bet a donut that your switch was about to die anyway. No surprises there, I've had to replace the key switch in every last one of my old tractor purchases. I really don't think you "burned out" the solenoid.
So your S/G was spinning the motor over fine with a new solenoid eh? As you repair or replace the electrical system, things will only improve. |
It was cranking them motor over but the battery only has 260 cold cranking amps so im not sure if thats enough it came out of my craftsman II tractor.
Where can I buy a key switch that will plug right into my current harness it has 3 prongs |
Not on a 1x8/9...that isn't a PO mod, that's factory.
I don't know why you would want to hook the safety switch to a toggle switch. I'm not a fan of by passing safety switches.
Im not going to use the pto for anything...
