I guess now is as good of time as ever to get the blade onto the 100. After all, I need to move some topsoil & crushed stone this week. Nothing like waiting until the last minute!
![]() Just curious what, if at all, am I missing here? Going by the manual it says for 70 & 100 models "without mower mounting backet" botl the extension braces to the subframe as show in "B" illistration 4. Place the subframe on the foot rest...... I don't have any "extention braces". So do I need these for sure so it will lift and lower properly? I did notice the sub frame would hit the tie rod that goes between the two wheels. So I mounted it on the top side instead of the bottom side. What size bolts/pins are you guys using to mount these or do I use a rod that runs the entire width of the tractor to pin both sides of the sub frame to the tractor frame? Also, what is the "spacing" between the sub frame tabs where it touches the tractor frame? If I place the one side tight to the tractor frame there is about 1/2" of space. This needed to let the blade flex and give a little when pushing? I still have to fabricate my lift arm bracket. Thought I'd put a chain or cable on it first to make sure I don't need anything else. DSCN3094.jpg DSCN3098.jpg DSCN3093.jpg DSCN3095.jpg DSCN3097.jpg
Mike Ontario, Canada IH built 982, IH built 782, IH built 782 parts tractor, 100 w/fenders & lights, #4 trailer, 42" front blade, IH 2B tiller, 12" Brinly plow, Brinly cultivator, IH push mower, Sims cab, IH snowthrower, 450 blower. Now everyone wants a Cub! ![]() Beware of the Wife
